Crew cab on Supercab frame?
I've got a 79 supercab 4x4 that I've been slowly building and the cab is totally rusted out and crap. In my search for a clean supercab cab I found a decent crew cab 2wd for sale. How hard would it be to mount a crew cab can on a supercab chassis? I'm going with a flat bed so the box is a non issue. I'm assuming I would need to move the rear cab mounts at the very least. Anybody ever done this or seen it? Or is this a pipe dream. Lol. Thanks
I'm in the process of doing exactly what your asking. But i started with a 2wd supercab long bed frame. front bolts up just as usual but you will have to move rear frame brackets. my build is a little different though as i started with a f600 crew cab and they have different mounts front and rear. My cab was so badly rotted i cut it in the middle of the door jamb and sectioned in the front half of a regular cab f150 a buddy had laying around. I'm still working on the rear cross member. The rear cab cross member on the f600 and bigger trucks is about 5 inches tall whereas a one ton and lighter trucks are only about 1 1/2 high. I am shortening my long bed by 11 inches. I have it mocked up on the frame and so far i don't believe ill have to run a body lift to keep the boy lines straight. The supercab frame has quite a rise in it about where the rear cab mounts go.
i havent started a build thread yet but have plenty of pictures from day one when my dad and myself went and cut the cab off the f600 up until now. if i can find the time ill try and start one. its been a little over a year and a half in the making. My daughter just turned one so she has stolen my attention away from it but id have it no other way. Hoping to get back out in the garage here soon
Pinto it looks as if you made your own radius arms so you can ditch the caps on the stock Ford C-Cap arms? Did you keep the 2wd coils or did you modify/fab the lower coil bucket? Are you going to use a tracbar or? We missed out on a crewcab that had 68K original miles for the wife and I do have a long bed super cab that I bought to shorten and put one of my other SC's onto. I am thinking looking at yours that maybe I should just try and fine a good crewcab cab and built it on the SC chassis and chop the bed as well.
Earnie Rosenow
11-10-2016 11:40 AM
pboffroad
11-07-2012 03:33 PM
59flatbedford
08-07-2009 05:15 PM
noyozoid
02-15-2004 12:06 AM
joncaudill
01-31-2004 05:47 PM
