P0304, 4.2 engine, need help diagnosing
Old 10-04-2016, 10:54 PM
Duncan Scott Millar's Avatar
Duncan Scott Millar
Duncan Scott Millar is offline
My E-250 4.2 has continuous miss on cylinder #4, p0304 changed coil pack, wires and plugs, No change. Cats were replaced a year ago fuel trim readings as low as -96.7%' as high as 53.3%. Would a cracked exhaust manifold cause this problem, after replacing coil pack, plugs and wires I noticed the crack between cylinders 5 and 6 on the engine side of the manifold about 1.5" long thickness of about sheet of paper. Here Is a picture of the fuel trim codes.
Old 10-05-2016, 11:42 AM
Duncan Scott Millar
Anybody out there want to take a crack at this?
Old 03-12-2017, 08:45 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
the EGR ports on my previous van V6 were all plugged up, except one cylinder; and that one cylinder had a misfire that was a bear to diagnose. PM me if you want more info.
Old 04-03-2017, 07:11 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
I just stumbled across your post. I realize it's 9 months old.
Did you get it fixed?
Sounds similar to the issue I had with isolator bolts and EGR ports. PM me an update please
Nomadic Van
3.8 & 4.2L V6
07-19-2016 10:02 PM
luckybarber
1997 - 2003 F150
07-29-2014 01:53 PM
97f150girl
1997 - 2003 F150
11-22-2007 12:04 PM
MikeFlorida
1997 - 2003 F150
08-10-2007 09:23 PM
Qpats
3.8 & 4.2L V6
05-19-2004 12:19 PM
Quick Reply: P0304, 4.2 engine, need help diagnosing
