cost to swap engines
How'd you determine the engine needs to come out?
I don't have alldata in front of me, I can check the labor time tomorrow, unless someone beats me to it.
Look on eBay for a good used engine if not try car-part.com most engines I get off there come with a warranty.
Then would you stud it delete it etc?
Engine
Diagnose/Test
Oil Leak, Diagnosis
C 0.0 1.0
Replace
Complete Assembly Without Transfer Of Parts
Does Not Include: Transfer Of Any Part Of Engine Or Replacement Of Optional Equipment.
B 16.1 16.7
NOTE
With Dual Alternators, Add
B 0.3 0.4
With Frame Mounted Battery, Add
B 0.1 0.2
Complete Assembly With Transfer Of Parts
Includes: Transfer Of All Fuel & Electrical Units. Does not Include Transfer Of Optional Equipment.
B 0.0 19.7
NOTE
B 0.0 0.4
B 0.0 0.2
Long Block
Includes: R&I Engine & Transfer All Necessary Components Not Supplied With Long Block.
B 0.0 24.7
NOTE
B 0.0 0.2
B 0.0 0.4
Short Block
B 24.0 27.7
NOTE
B 0.1 0.2
To Grind Valves, Add
One Bank
B 4.0 5.0
Both Banks
B 7.8 9.4
B 0.3 0.4
Overhaul/Rebuild
Includes: Disassemble & Clean Engine. Ridge Ream & Hone Cylinders, Fit Pistons, Rings, Pins, Main & Rod Bearings, Grind Valves & Tune-Up.
A 0.0 39.2
NOTE
A 0.0 0.2
A 0.0 0.4
This is what Alldata shows me.....
I would try to get a 100% diag before tearing the motor out
Diagnose/Test
Oil Leak, Diagnosis
C 0.0 1.0
Replace
B 16.1 16.7
NOTE
B 0.3 0.4
B 0.1 0.2
B 0.0 19.7
NOTE
B 0.0 0.4
B 0.0 0.2
Long Block
B 0.0 24.7
NOTE
B 0.0 0.2
B 0.0 0.4
Short Block
B 24.0 27.7
NOTE
B 0.1 0.2
One Bank
B 4.0 5.0
Both Banks
B 7.8 9.4
B 0.3 0.4
Overhaul/Rebuild
A 0.0 39.2
NOTE
A 0.0 0.2
A 0.0 0.4
Engine
Diagnose/Test
Oil Leak, Diagnosis
C 0.0 1.0
Replace
B 16.1 16.7
NOTE
B 0.3 0.4
B 0.1 0.2
B 0.0 19.7
NOTE
B 0.0 0.4
B 0.0 0.2
Long Block
B 0.0 24.7
NOTE
B 0.0 0.2
B 0.0 0.4
Short Block
B 24.0 27.7
NOTE
B 0.1 0.2
One Bank
B 4.0 5.0
Both Banks
B 7.8 9.4
B 0.3 0.4
Overhaul/Rebuild
A 0.0 39.2
NOTE
A 0.0 0.2
A 0.0 0.4
Diagnose/Test
Oil Leak, Diagnosis
C 0.0 1.0
Replace
B 16.1 16.7
NOTE
B 0.3 0.4
B 0.1 0.2
B 0.0 19.7
NOTE
B 0.0 0.4
B 0.0 0.2
Long Block
B 0.0 24.7
NOTE
B 0.0 0.2
B 0.0 0.4
Short Block
B 24.0 27.7
NOTE
B 0.1 0.2
One Bank
B 4.0 5.0
Both Banks
B 7.8 9.4
B 0.3 0.4
Overhaul/Rebuild
A 0.0 39.2
NOTE
A 0.0 0.2
A 0.0 0.4
cpetersen
02-12-2011 07:53 PM
pidford
09-29-2004 04:48 PM
