What to look at in an engine?
Hey all,
I'm looking at possibly picking up and engine out of a 95 to stick in another truck, or to build and swap out with mine, not sure yet. Anyhow, the seller has the engine out and sitting on a crate. What do you generally look for or at when picking up an engine like this?
I will be checking the obvious things such as the turbo wheel and making sure everything is covered or plugged, but other than that what should I be looking at?
Thanks,
Baatzy
Thanks,
Baatzy
One thing I learned the hard way: If you are planning on using it without rebuilding it - get a decent cylinder leak-down test kit (not the stupid HF unit), and practice with it on your own vehicle before using it for real on the prospective engine. You also need to make sure you have a decent supply of air - many home compressors will have you hangin' around - waiting for 100 PSI to show on the supply side. I think the nut on the dampener (to hold the engine still) is 15/16".
If you have what you need at your disposal and/or aren't powering up (no warranty with bigger sticks), then yes - a reman is less hassle.
OldWoodsDiesel
07-30-2013 07:53 PM
