cost to swap engines
Thinking of solutions for my e450. What would be a fair price to plug in for shop labor on removing/replacing the engine? Whether I fix the engine in it or swap in a reman, the engine has to come out.
How'd you determine the engine needs to come out?
I don't have alldata in front of me, I can check the labor time tomorrow, unless someone beats me to it. Look on eBay for a good used engine if not try car-part.com most engines I get off there come with a warranty. Then would you stud it delete it etc? |
Labor is about 20-25 hours to R&R engine I think Im doing an 08 E350 now. Vans do suck.
6C2Z 6006 AARM is what I have, its a complete minus turbo etc.
Originally Posted by 2006powerstroke90
(Post 16607964)
Engine
Diagnose/Test Oil Leak, Diagnosis C 0.0 1.0 Replace Complete Assembly Without Transfer Of Parts Does Not Include: Transfer Of Any Part Of Engine Or Replacement Of Optional Equipment. B 16.1 16.7 NOTE With Dual Alternators, Add B 0.3 0.4 With Frame Mounted Battery, Add B 0.1 0.2 Complete Assembly With Transfer Of Parts Includes: Transfer Of All Fuel & Electrical Units. Does not Include Transfer Of Optional Equipment. B 0.0 19.7 NOTE With Dual Alternators, Add B 0.0 0.4 With Frame Mounted Battery, Add B 0.0 0.2 Long Block Includes: R&I Engine & Transfer All Necessary Components Not Supplied With Long Block. B 0.0 24.7 NOTE With Frame Mounted Battery, Add B 0.0 0.2 With Dual Alternators, Add B 0.0 0.4 Short Block Does Not Include: Transfer Of Any Part Of Engine Or Replacement Of Optional Equipment. B 24.0 27.7 NOTE With Frame Mounted Battery, Add B 0.1 0.2 To Grind Valves, Add One Bank B 4.0 5.0 Both Banks B 7.8 9.4 With Dual Alternators, Add B 0.3 0.4 Overhaul/Rebuild Includes: Disassemble & Clean Engine. Ridge Ream & Hone Cylinders, Fit Pistons, Rings, Pins, Main & Rod Bearings, Grind Valves & Tune-Up. A 0.0 39.2 NOTE With Frame Mounted Battery, Add A 0.0 0.2 With Dual Alternators, Add A 0.0 0.4 This is what Alldata shows me..... I would try to get a 100% diag before tearing the motor out |
(Post 16609053)
Engine
