Tranny id
Old 09-25-2016, 01:36 PM
Chargergirl75's Avatar
Chargergirl75
Chargergirl75 is offline
Tranny id
I'm trying to Id my transmission. C5MP 7006 A 22DIF. from what ive found it may be an MX? Obviously not the c6 the guy said it was. Bought it attached to a seized 390 out of a 69 galaxie. Getting ready to install having bought components to a c6 only to see that it's not matching up. Putting it into a 71 F-100 changing from a manual 4 speed to an automatic for my daughter (I know I'm horrible). HELP?
Old 09-25-2016, 09:38 PM
matthewq4b's Avatar
matthewq4b
matthewq4b is offline
If the Body is cast iron it likely is is a MX, FX, FMX. Ideally we need the ID tag info to properly identify the the trans.
Old 09-25-2016, 10:05 PM
Chargergirl75
I forgot to post the Id tag. It's PFA B 179314.
Old 09-25-2016, 11:41 PM
matthewq4b's Avatar
matthewq4b
PFA-B Trans Type MX, 8 Cyl 390 1967 Ford (column shift (exc. P/C & fleet)
PFA-B1 Trans Type MX, 8 CY 390 1968 Ford (column shift)
Hope this helps.
Old 10-02-2016, 12:52 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
It's an MX Cruise-O-Matic, it would not be installed in a 1969 Ford w/a 390. '69 390 would have come w/a C6.
So now you have to ask yourself, is the 390 from the 1967 Ford that this MX came in (see post 7), or?
C6 has 17 trans pan bolt holes, FX/MX/FMX Cruise-O has 14 trans pan bolt holes.
blalock51
04-20-2018 03:46 PM
1956_F100
03-07-2017 08:49 PM
ryanf77
16
05-07-2015 09:51 AM
tankrsc
10-16-2007 08:45 PM
sinchicken
02-20-2005 09:54 PM
Quick Reply: Tranny id
