FORD F150 RUNNING ISSUES AFTER MAIN SEAL REPLACEMENT
HELLO,
I RECENTLY HAD THE MAIN OIL SEAL CHANGED ON MY 2006 FORD F150 BECAUSE THERE WAS A SMALL LEAK BETWEEN THE MOTOR AND TRANSMISSION. I ALSO HAD ALL THE SEALS ON THE MOTOR AND TRANSMISSION CHANGED AT THE TIME. I AM NOW HAVING ISSUES WITH THE TRUCK THAT IT SHAKES VIOLENTLY WHEN I TURN ON THE TRUCK, IT STOPS SHAKING IF I ACCELERATE BUT ONCE I STOP IT STARTS TO SHAKE AGAIN. ALSO IF I PUSH PAST AROUND 40MPH THE CAR STALLS AND SEEMS TO WANT TO TURN OFF. I HAVE CHANGED THE SPARK PLUGS AND THE SPARK PLUG WIRES, AND CHECKED THE TRANSMISSION FLUID BUT SO FAR NO LUCK. I HAVE TRIED TO SCAN THE TRUCK FOR CODES BUT THE SCANER SHOWS NO CODES. ANY IDEAS AS TO WHAT COULD BE WRONG? THANKS
Man_tlac83
1997-2006 Expedition & Navigator
04-14-2012 09:57 PM
ratzmann1
04-25-2009 10:27 PM
Torque1st
11-16-2002 11:26 AM
