Pow Steer box seal replacement
Old Nov 7, 2002 | 03:10 AM
Torque1st's Avatar
Torque1st
Posting Legend
Old Nov 16, 2002 | 09:40 AM
boringoldman's Avatar
boringoldman
Howdy,
I've got a '77 F250 4x4 with a leaking ps gearbox. It's the seal that connects to the steering wheel shaft. Is there a way to replace that seal without pulling the entire box? I am resourceful, and can "improvise". Ie, I'm not affraid to do unorthadox things. Afterall, this truck has been used for target practice and had large objects fall on it. Nevertheless, I still love this truck enough to treat it like a king. It has done remarkable things for me. Ok, I'll shut up.
Old Nov 16, 2002 | 11:08 AM
Torque1st's Avatar
Torque1st
Posting Legend
Pull the rag joint, yank the seal, clean everything up, use rock to pound seal back in... -hehe
Actually, I have a 83 E350 that had that seal leaking so bad it would dump out all of the fluid over night. I refilled the steering unit with a whole bottle of transmission seal conditioner and topped it off with regular fluid and no leaks since. It has been 6 months and everything works perfectly. I wish I could tell you what brand the seal conditioner was but I tossed the bottle in the dumpster. I bought it at Oreilley.
I prefer granite but limestone will work in a pinch!
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Nov 16, 2002 | 11:26 AM
boringoldman
I'll just use my noggin! Actually, I tried the seal conditioner several times. But jeez, if it worked in your situation, it should work here too. I think the seal needs to go.
Thanks
