6.4 transmission pan on a 6.0 ?
Old 07-28-2016, 07:36 PM
justin414182's Avatar
justin414182
justin414182 is offline
What are the advantages of a 6.4 transmission pan on a 6.0 and is it worth doing ?
Old 07-28-2016, 07:44 PM
Magnolia Tom's Avatar
Magnolia Tom
Magnolia Tom is offline
With the 08 pan, you can install the 08 filter which is full flow. Much better than the roll of toilet paper in the bypass
Old 07-28-2016, 11:24 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
and it filters 100% of the fluid all the time, not just 10%... what the toilet paper filter does.
Old 07-29-2016, 01:57 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
And the price is not really that bad for the pan and filter.
You can go to Ed at FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
He started here and tends to really give back to the community.
Sean <BR>
6.0L Tech Folder
Old 07-29-2016, 01:43 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
I figure they upgraded it for a reason and it wasn't because it looks pretty. I did mine around 100k miles, good excuse to drop the pan and check the magnet. Re-used the old seal with no issues, just stuck the new filter in and bolted the new pan on same as if I was putting the old stuff back in.
Old 07-29-2016, 03:05 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
One thing to be sure of is to get the oil filter neck seal out of the bore.
They can and do come off the filter and stay behind. Use a plastic tool
to hook it and remove. That bore is soft aluminum and can score with
out much effort and leave you with a suction leak and pull air into the
system. That would make for an unhappy transmission.
Sean <BR>
6.0L Tech Folder
Old 07-29-2016, 07:17 PM
Arizona97's Avatar
Arizona97
Arizona97 is offline
How often should you change that filter?
Ed
Old 07-29-2016, 08:05 PM
texastech_diesel
Token Redneck
60k per the 6.4L trans fluid change guide.
I assume fluid change is analogous with a filter change since it's only got the one, the maintenance guide I pulled for an '09 says trans fluid change at 60k, but IIRC off the top of my head I'm remembering the filter changes at the same interval.
Old 07-30-2016, 07:13 PM
diesel_dan's Avatar
diesel_dan
diesel_dan is offline
Correct! And just to show us how stout these transmissions are: the TP filter only gets to filter 10% of the oil IF the thermostat is open and sending fluid to the front cooler (170 degrees?).
Here's a thread I did back when I swapped mine out, there's some BS in the middle pages, but still mostly ok stuff:
https://www.ford-trucks.com/forums/1...ns-filter.html
1L243
02-16-2018 11:02 AM
turbotuner
03-28-2016 05:53 PM
OJs DNA
12-15-2015 07:23 PM
Smokiesman
18
12-31-2010 09:20 AM
ramtuff52
Massachusetts Chapter
12-25-2009 10:09 AM
Quick Reply: 6.4 transmission pan on a 6.0 ?
