Oil pouring out
Yes, it does. Been there, done that. Sealant was just a little too thin in one spot on the back. Dropped the engine in, started it and immediately pulled it right back out. I now dry fit oil pans and eyeball the gaps at the front and back curved areas. The gaps do vary somewhat from engine to engine; probably due to manufacturing tolerances on the oil pans and front and rear covers. That's another reason I won't bother trying a gasket, no matter who makes it.
I don't think it is coming from the high pressure side. It it were I don't believe it would ever crank. The HPOP does not pump a lot of volume just pressure. The LPOP on the other hand does. The pedestal or turbo orings pinched and squirting out the back side to the firewall could also be a culprit. If it is truly pumping out 2-3 gallons of oil in 20 seconds then I say low pressure oil somewhere.
Excellent! Thanks for doubling back and letting us know what you discovered.
When I ran into that scenario last January, I had done the EBPV delete and bellowed up-pipe installation (among a LOT of other things), and I managed to get the big o-ring out of position while re-installing the turbo, and it mage a HUGE mess within only a minute of running the engine... lost two gallons of oil (BRAND NEW oil) faster than I would have thought possible.
86scotty
07-02-2011 10:40 PM
