Blown rear engine seal?
Old Nov 13, 2008 | 01:27 PM
skemcis's Avatar
skemcis
After a 1300km run to the north. Climbing a moderate hill, the engine started losing power, and I smelled burning oil. Pulled over and checked oil. Nothing on dipstick. Put in 5 litres of oil and ran another 20km, stopped and checked oil. Nothing on dipstick. Started engine, looked underneath and oil flying everywhere from back of engine. Shut off, and towed for 200 km. Great start for winter work eh? Question, without pulling transmission etc, how do I find out what type of rear seal is in there. Or, is it possible that a camshaft plug/cap let go? Either way, 5 litres of oil in 20km is a baaaad leak. any suggestions?
'96 F350
7.3
5spd 4x4
Old Nov 13, 2008 | 02:07 PM
otpracer100's Avatar
otpracer100
That really sucks.I can't really help you except to tell you that a blown rear seal on these trucks is very uncommon from what I've read on here. Someone more knowledgable than me will chime in soon.Good luck
Old Nov 13, 2008 | 02:27 PM
Action4478's Avatar
Action4478
I'd be looking at the high pressure oil lines from the HPOP ,,possibly the oil cooler ..(not likely the rear main )..
Any oil from the top of the motor will make its way down to the rear of the engine ..
If the engine is still running ok ,,must not be too bad a leak
Old Nov 13, 2008 | 02:31 PM
Norton72's Avatar
Norton72
Well, I had a really bad oil leak not too long ago that turned out to be a cracked turbo. But mine wasn't as bad as yours. The first thing you will be asked about your leak is, are you sure it's not coming from above, from the top of the motor. If it was it would run down the back of the motor and would make you think "rear main seal." That's the first thing I thought of on mine. If you are loosing that much oil that quickly, it's gotta be coming out under a lot of pressure. That makes me think High Pressure Oil Pump -- there are lots of folks here much more knowledgeable than me that I am sure will be along directly. Meanwhile, I would go ahead and check to see if that leak is originating at the top of the motor so that you will be prepared to answer that question. Look down from the top and see if you see oil in the valley.
Old Nov 13, 2008 | 02:33 PM
Norton72's Avatar
Norton72
See how slowly I type? They already got here before I could finish my message.
Old Nov 13, 2008 | 02:48 PM
Neal 97 250's Avatar
Neal 97 250
Definately look on top of the motor first. You may have to clean it then crank it to find the general vacinity it is coming from. Post back.
Norton you need reps. You are every where trying to help. Thanx. That is what this place is all about.
Old Nov 13, 2008 | 03:02 PM
Norton72's Avatar
Norton72
Problem is, I don't know Shiite. Only the little I've learned in one month, and that's very limited.
Thanks though, that means a lot.
Old Nov 13, 2008 | 05:20 PM
84-250's Avatar
84-250
Look at the high pressure oil gallery end plugs. They are the 2" plugs at the front and rear of the heads with a 1/2" square notched in the center
Old Nov 14, 2008 | 01:00 PM
jeep1947's Avatar
jeep1947
I am betting on HP oil rail plug they make one helluva mess had to replace left front 2 years ago I also thought rear main was shot. Aint nothing under my truck ever gonna rust though.
Old Nov 14, 2008 | 01:34 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
here you can see the rear plugs:
Old Nov 14, 2008 | 01:40 PM
jeep1947's Avatar
jeep1947
New replacement plugs have a blue O ring IIRC.
Old Nov 14, 2008 | 01:41 PM
Action4478's Avatar
Action4478
here you go Jose...
Fixed it for you ...
Old Nov 14, 2008 | 01:49 PM
ron86toy's Avatar
ron86toy
Same boat as you less than a year ago...I have learned tons from here and learn more everyday....I dont think it stops....I try and help as much as I can....If I cant I end up searching for the persons problem just to ease my mind so I know it for future reference.
Old Nov 14, 2008 | 02:55 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Originally Posted by Action4478
here you go Jose...
Thanks, I dont know why the pic cant see in my post but is this one:
Old Nov 14, 2008 | 03:12 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I dont understand, some times when I open this posts, the pic I posted doesnt appears and other times it does; any way you can click in the square with the red X with a righ click in the mouse, then go to properties and copy and paste the URL and use your PC and see the pic.
Well here is the link
DSCN0751 pictures from friends & fun photos on webshots
