Oil Leaks
Old Oct 30, 2008 | 01:58 PM
matt71's Avatar
matt71
Oil Leaks
Is there any way to tell if the turbo pedastool is leaking oil without starting the motor? I wanted to fix it but I cant start it because my injectors are on their way out to Rosewoods. I also have the transmission out, dont know if this will help to see anything or not. I have oil running out of the valley down the back of the motor, but it is also running down the front of the motor to on the left side.
Old Oct 30, 2008 | 02:08 PM
Action4478's Avatar
Action4478
I'd be looking at the lines from the high pressure oil pump....
Old Oct 30, 2008 | 02:54 PM
foxracing0934's Avatar
foxracing0934
It could be more than one leak. The galley plugs on the back of the heads have bad o-rings and if you haven't updated them yet it could be those that are leaking. When mine went it was leaking quite a bit of oil.
