Wont move
Old 06-29-2016, 01:53 PM
redneckunleashed's Avatar
redneckunleashed
redneckunleashed is offline
Wont move
Just bought an 01 F250 7.3 but it will not move I think it has something to do with the fuses because it won't go in forward or reverse but I can't find an accurate diagram For fuse box I'm missing probably 8 fuses underneath the dash and I think one of them has to control the transmission module. I would appreciate it if I can get some ideas on what it could be if someone doesn't think the fuses
Old 06-29-2016, 08:24 PM
Otto396's Avatar
Otto396
Otto396 is offline
The overdrive light coming on? Is it flashing? Does the detent work? Any loose plugs on the transmission or on the driver fender where the transmission plugs are?
Does it have fluid in the tranny?
Old 06-29-2016, 08:36 PM
redneckunleashed
No overdrive light is on. Have a service engine soon light. Trans has fluid. Plugs are in too. Tryed to put in 4x4 and it would not work.
Old 06-30-2016, 11:13 AM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
Check the line pressure bolts on top of the valve body. They have a tendency to back out. You could have just score this truck is that's the only issue!
If the fluid is still red looks and smells good, you may have just bought a winning lottery ticket. A fuse does not control the transmission by the way.
Old 06-30-2016, 11:26 AM
redneckunleashed
Do you know to tell if it has or not
Old 06-30-2016, 11:44 AM
Otto396's Avatar
Otto396
Otto396 is offline
Have you checked the detent on the side of the transmission? It controllers what gear the truck is in. If the cable isn't on or isn't held from moving that could be it.
Old 06-30-2016, 12:07 PM
redneckunleashed
It move thought the gears. cable is held on by a zip tie but it does go in gear.
Old 06-30-2016, 01:55 PM
nlemerise's Avatar
nlemerise
nlemerise is offline
Are you sure the transfer case is in gear?
Old 06-30-2016, 02:38 PM
redneckunleashed
Transfer case wont go into gear which one is it normally four wheel drive switch or solenoid
Old 07-01-2016, 12:19 PM
nlemerise's Avatar
nlemerise
I may not understand what you have replied to my original question "Is the transfer case in gear?" The truck will NOT move (by putting the transmission into any gear) if the transfer case is in NEUTRAL. I don't have the switch for selecting, I have a manual floor lever for engaging the transfer case (2 high, 4 high, neutral, & 4 low) with manually locking hubs .
htownoag
08-27-2015 06:17 AM
GrizzlyPiet
1983 - 2012 Ranger & B-Series
12-05-2010 10:39 PM
cowboy51
04-12-2009 11:26 AM
NEWTOYOUAUTO
12-11-2008 07:58 PM
eyball
07-01-2005 08:21 AM
Quick Reply: Wont move
