od light flashing at start up and park
Old 08-26-2015, 11:05 PM
htownoag's Avatar
htownoag
htownoag is offline
So last night i turned on my engine for the first time so i was content and called it a night. Today i came home from work and adjusted the distributor And wanted To Move the Truck Forward. To My Disappointment It Wouldnt Move So I Thought It was The Fluid I Lost When I Removed It And The new(jy) Lines and The Oil Cooler in Rad that Had The Atf Low. Then I Noticed The OD Light Flashing. I Turned Off The Truck And Restarted After 2 Minutes. Immediatly The Light Begins To Flash. #13fuse Is Good Maxi Fuse Is good.
Is The OD Telling Me Fkhid Is low?
95xlt F150
4r70w
I Checked The range Selector,Vss,and white Plug Everything looks Good. The Truck Has Been Sittin For 5months Without Engine And Tranny. Tranny Was Some what covered Under A Roof.
Im Going To Top Of The Mercon tomorrow and See What Happens
Old 08-27-2015, 06:17 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,570 Likes on 1,049 Posts
The OD light doesn't flash from low fluid, unless it is so low the trans doesn't have any. If flashes to tell you that an error code has been stored in the computer's memory. In order to know what's wrong you need to read the codes.
Try this: Ford OBD Trouble Codes ?
Jaime74656
03-10-2015 03:29 PM
Scaper
04-03-2012 03:54 PM
1Digger
1983 - 2012 Ranger & B-Series
06-17-2008 07:06 AM
lewjayjr
02-23-2005 01:37 PM
mattskn
01-27-2005 03:30 PM
Quick Reply: od light flashing at start up and park
