1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2000 F350 Front Locking Hubs (Different)
Old 06-08-2016, 05:30 AM
Retreever's Avatar
Retreever
Retreever is offline
I was planning on removing and servicing my front locking hubs and have been researching heavily online (video's, forum postings and other instructions).
I felt I was sufficiently prepared but when I went to start I found my trucks front wheel set up looks very different then anything I have seen in my research now I'm not sure if I should attempt this. With the hub cap removed the hub itself still looks like it is buried in the wheel and not easily accessible.
Please see pictures, does anyone recognize this configuration and does anyone have how to service auto locking hub instructions for this specific wheel set up?
TIA
Roger
Close up of front wheel with hub cap off.
Close up of opening with hub locking mechanism
View behind wheel looking through opening in the wheel rim
Old 06-08-2016, 06:35 AM
rdlouks's Avatar
rdlouks
rdlouks is offline
What are your concerns?
Since your Super Duty is a Dually you must remove the tire & wheel, then the adapter plate (shown in your last picture)from the hub to gain access to the locking hub assembly.
It appears your truck is equipped with what I call the "Dorman" style locking hub, instead of what I like to call the "Warn/OEM" style. The only difference is how they are held in place. The "Warn/OEM" style use 3 or more allen head cap screws, the "Dorman" Style uses a large snap ring. Here is a video of removal procedure of your style locking hub.
Warn/OEM Style
Dorman Style
Old 06-08-2016, 06:59 AM
Retreever's Avatar
Retreever
Reply to thread '2000 F350 Front Locking Hubs (Different)'
[QUOTE=rdlouks;16342971]What are your concerns?
Thanks for the response rdlouks, the adapter plate you refer to , I'm assuming to remove that would require undoing the nuts shown in my picture?
My concern was exactly what you clarified for me, all of the videos I had seen previously showed you could do this work without removing tire/wheel and there was no mention of the adapter plate.
Thanks Again
Retreever
Old 06-08-2016, 09:33 AM
Hoss416's Avatar
Hoss416
Hoss416 is offline
He has stock Ford locking hubs. The early models came with the black plastic hub in the second picture. The auto/manual hub pictured is for an 08 and up with ESOF.
Old 06-08-2016, 12:36 PM
Retreever's Avatar
Retreever
Hoss416, just FYI my truck has the ESOF system with the 3 position rotary switch 2WD, 4HI, 4LO.
Retreever
Old 06-08-2016, 12:54 PM
Hoss416's Avatar
Hoss416
Hoss416 is offline
Sorry, I wasn't implying that you don't have ESOF. I was just clarifying the difference between the pictures. 2000 still had the black plastic hubs from the factory. In fact, my 04 had them with the auto/manual feature. I'm not sure if the newer hubs are interchangeable. It's worth looking into though.
dadstan76
09-15-2015 12:18 PM
Caleb7250
11-17-2014 07:21 PM
amigrad06
09-04-2008 02:44 AM
automike25
19
01-27-2007 07:23 PM
The Groovy One
1978 - 1996 Big Bronco
01-21-2005 05:22 AM
Quick Reply: 2000 F350 Front Locking Hubs (Different)
