please help id this hub
Old Sep 12, 2015 | 09:00 PM
dadstan76's Avatar
dadstan76
I need to replace the worn Selectro hubs in my 76' F150. Can anyone tell me which hubs I need to buy (looking at Mile Marker) and how do I get the gear off that's in the middle of the hub (I assume I need to). Thanks so much! And yes, I sawed the hub bolts off, they rusted in place.
Old Sep 14, 2015 | 02:48 AM
hayden01's Avatar
hayden01
For the Mile Marker brand there looks to be two types:
1) Mile Marker Street Master, part number 302. Nylon reinforced fiberglass dial.
2) Mile Marker Supreme, part number 104. Stainless steel dial.
Both should have perty much the same internals, except for the dials.
Now to get the hub body out there is a large retaining ring just inside the hub opening, you can use two small screwdriver or small hook/pick set to get out. Then on the center shaft theres a snap ring that needs to be removed. Once thise two rings are removed the hub body shound slide out. Now would be a good opportunity to pull the wheel bearings out and repack those if there in good condition as well.
Old Sep 14, 2015 | 02:55 AM
Skip1970's Avatar
Skip1970
worse hubs ever, mile marker supremes....
Old Sep 15, 2015 | 12:18 PM
dadstan76's Avatar
dadstan76
Thanks for your help Hayden01, I went out to recheck because I was just sure I didn't overlook any snap rings and sure enough I missed the biggest one. Took it out and the hub slid out fairly easily. Surprised to see the hub had "made in Taiwan" on the back of it.
Mikey Oldaker
Mar 20, 2012 10:18 PM
turbill
20
Aug 5, 2011 01:33 PM
distortedcloud
Dec 19, 2007 10:15 PM
automike25
Jan 27, 2007 07:23 PM
Yachtman
Jan 28, 2004 02:08 PM
