How to patch puncture hole in steel gas tank ?
Old 06-05-2016, 08:51 AM
scottperkins's Avatar
scottperkins
scottperkins is offline
suppose a puncture hole were to inadvertently appear in the bottom of
my gas tank? What would be some good ways to plug the hole ?
I'm thinking a fine thread stainless steel flat head screw that was screwed
into a tapped hole with special glue/sealant and a washer would probably
work.
You're probably catching on now..... A non electric drill would probably
be best to drill into the bottom of a full gas tank but all I have presently are battery powered and 100volt drills.
Old 06-05-2016, 04:11 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
I would drain the tank so no dripping.. sand the tank with rough sandpaper about 3 inches in diameter.. GEt it clean, but plenty of scratches to roughen it up....... Mix up an ounce of JB weld and smear it on the area as a patch. Rub it into the scratches with your finger to get good contact. spread it around with a small putty knife so it is 3 inches in diameter, feathered out thin on the edge and little over 1/8 inch thick over the hole area.
Old 06-05-2016, 04:13 PM
steve(ill)'s Avatar
steve(ill)
if you cant drain the tank, sometimes you can use a very small sheetmetal screw and get it in half way. smear RTV over the exposed threads and screw it in snug.. wipe off excess RTV..... or you can use a tin roofing screw with the rubber washer ........if that stops the drip, then do the JB weld patch over the top of the screw.
Old 06-05-2016, 04:22 PM
kd4gij's Avatar
kd4gij
kd4gij is offline
Get something like this.
Amazon.com: Permatex 09101 Fuel Tank Repair Kit: Automotive Amazon.com: Permatex 09101 Fuel Tank Repair Kit: Automotive
That said I would find a better way to drain the tank than drilling a hole in it.
Old 06-05-2016, 09:14 PM
Torky2's Avatar
Torky2
Torky2 is offline
That's the best idea by far!
Old 06-05-2016, 10:06 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Now that you have a pretty nice hole drilled there, wouldn't a drain petcock be kind of handy sometimes? "Just thinkin' out loud."
Old 06-05-2016, 10:48 PM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
Yes, for anyone to steal your gas.
Old 06-05-2016, 11:21 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Well I spose. But, if they really want it, they can simply cut the hose too, that's on thousands of trucks just below the in cab tank. See where I'm goin' with that?
Old 06-06-2016, 10:29 PM
z 97ford1's Avatar
z 97ford1
z 97ford1 is offline
WOW, I would not even think twice......JUST REPLACE the tank, their cheap. This is fuel we're talking about here, people get blown up because of those things.
Old 06-07-2016, 04:55 AM
ford4life2016's Avatar
ford4life2016
ford4life2016 is offline
Weld it
When "someone" put a hole in my tank, I ended up taking the tank off empty all the gas and let it all evaporate then I flushed the tank with water and welded the hole shut. The hole was the size of a dime. (punch hole).
62 red truck
11-19-2006 10:49 PM
bluneon
24
06-22-2006 03:40 PM
fightmike
Paint & Bodywork
04-28-2006 02:40 PM
rlangs58
10-26-2004 02:15 PM
70f250
10-08-2004 06:41 PM
Quick Reply: How to patch puncture hole in steel gas tank ?
