I have a 93 F-150 with 4.9L M5 transmission and when I push on the clutch peddle to shift, the peddle makes a popping noise. I looked under the dash and could not see any obvious problems. I did notice that the peddle has a bee hive looking spring I assume is a return spring.
Anyone ever have a clutch peddle make a popping noise and how did you fix it?
