Clutch Noise
Old Apr 10, 2008 | 07:00 PM
murphy's Avatar
murphy
Clutch Noise
Hey, my 1999 3.0 4x4 ranger with a 5 speed makes loud creaking noise when letting off the clutch. Is this a common complaint with the Ranger 5-speed ? It has done it for a couple of years, finally starting to annoy.
Old Apr 10, 2008 | 09:04 PM
Rangerman Stan's Avatar
Rangerman Stan
Do you know if the noise is there when you let off the clutch and the engine is not running? Even if it's not, it's possible the noise could be from the clutch pedal pivot point up under the dash. It could also be from the push rod for the clutch cylinder, where it attaches to the pedal. You might be able to make the noise go away by squirting some WD40 on the pivot points of both places.
Old Apr 11, 2008 | 03:24 PM
Pablo-UA's Avatar
Pablo-UA
It may be noise of tranny mounts, engine mounts, DS, rear end....
