1978 - 1996 Big Bronco
clutch noise
Old Jun 20, 2001 | 12:32 AM
skipper's Avatar
skipper
clutch noise
Whenever I push the clutch in it makes a funny noise, but only for a couple of seconds and then it stops. If you sound out this noise "ffftfffftfffftffft", that is what it sounds like. My throw-out bearing is relatively new and has less than 2000mi on it. Any ideas?
Old Jun 20, 2001 | 08:52 PM
billyb's Avatar
billyb
clutch noise
does the clutch make the noise, or the transmission?
Old Jun 23, 2001 | 10:37 PM
skipper's Avatar
skipper
clutch noise
It has to be the clutch. The transmission has never made any noises and it only happens with the clutch pushed in all the way. If you push the clutch almost all the way it doesn't make the noise.
Old Jun 24, 2001 | 08:47 AM
billyb's Avatar
billyb
clutch noise
what year truck is it? and also did you replace clutch while replacing throwout bearing? i assume it did not make the noise before the replacement.
Old Jun 25, 2001 | 09:44 PM
skipper's Avatar
skipper
clutch noise
Before I replaced the throw-out bearing it made a horrible squealing noise. It was like that when I bought it. I trailered it home and replaced the bearing the next day. The clutch and flywheel both looked to be fine. The clutch is supposedly only two years old. When I put in the new bearing in a year ago it was fine. This noise only started recently.
Old Jun 25, 2001 | 11:30 PM
whomrig's Avatar
whomrig
clutch noise
There is a pilot bushing/bearing in the end of the crankshaft that the input shaft slides into. This could be your noise.
Wayne 1960 F-350
e-mail
http://home.pacbell.net/whomrig
Old Jun 26, 2001 | 03:57 PM
AlM's Avatar
AlM
clutch noise
