Hot starting.
Hot starting.
Good evening, so in the past 3 weeks I noticed that when my truck is at operating temperature and I go to crank her over it sound like the starter is very weak or something but if I want a while it cranks over normally. I checked my wiring and checked my ground everything seems to be in tact I even added a ground from the engine to the frame. I thought that was it but it was back it the next day. I have a video so you could see what I mean.
fordboy300, during the last 3 weeks, has the ambient temperature gotten warmer? It might have been cooler, last year, when the distributor was first installed. Do as Franklin2 suggested. Loosen the distributor hold-down bolt and rotate the distributor body clockwise just slightly [your engine is a six cylinder, right?], secure the bolt, and start.
You can take the cap off, take the rotor off, and then play with the top of the dist where the weights are and see if it's sticky. A little wd40 works wonders.
Check the timing, also check to make sure the vacuum advance isn't sticking in the distributor where it rotates to pull the trigger/sensor to advance/retard the timing. I've had that happen before and damn near pulled my hair out trying to figure out why it would drag the starter down so hard sometimes and sometimes not. Even at a low timing setting. It doesn't have to stick very much at all to cause a pretty big starter drag. A simple emery cloth sanding on the breaker plate where the assembly rotates and some high temp synthetic grease fixed it.
I noticed you said you have a DUI distributor. They sell them in the Duraspark version as well as GM HEI. The problem I specified I had was with a Duraspark distributor but the advance system in the distributor can get dirty/corroded in any mechanical/vacuum advance distributor and cause the same issue.
Take it on a hot day and make sure to get it good and hot so you can show them what the problem is. If it is the timing they should be able to fix it in 5 minutes.
![Wink](images/smilies/wink.gif)
To see if too much timing advance is your problem, there's no need to adjust the distributor. Simply disable the ignition and try cranking the engine. Obviously it won't start, but if the cranking speed returns to normal, the timing was as least part of your problem. To disable the ignition, simply pull the center lead from the distributor and ground it.
If the cranking speed is still slow even with the ignition disabled, run a voltage test on the complete starter circuit. Here's a good explanation of how it works. This is a very simple test and can be done in minutes, and will find faults that won't show with regular ohmmeter checks. I swear up and down by the voltage drop test. Even if you don't fully understand why it works, please take my word that it does and give it a go anyway:
Starter Voltage Drop Test Explained in Plain English | AutoTechnician.org
hharris8
67
08-16-2016 05:24 PM
64'F100BobbySurfer
07-27-2015 06:56 AM
dogmantra
10-04-2010 12:43 AM
