Timing going out
Old Mar 4, 2012 | 08:48 PM
rostronic's Avatar
rostronic
Timing going out
I just replaced my timing chain and gear set.
Went with a double roller.
Set it to zero advance.
At TDC set the rotor to #1.
Got everything back together, truck fired up and ran fine. Ran it for 5~10 minutes, got it up to temperature and shut it down to set the idle and then adjust the timing.
Went to start it up and wouldn't start.
Checked the distributor and the timing was off.
At TDC the rotor was 90 degrees off ( clockwise of #1 )
What would cause the rotor to be off?
Haven't reset the timing yet, because I can't get the distributor out, turns but can't pull it out, maybe because it is warm
Thanks,
Bob
Old Mar 5, 2012 | 09:04 AM
earthquake68's Avatar
earthquake68
Pull the distributor back out. A broken roll pin on the distributor gear will do that. While it's not super common, it does happen. Be careful pulling the distributor back out so you don't drop the gear in the engine.
Old Mar 5, 2012 | 10:39 AM
piratius's Avatar
piratius
Yeah, if you *just* put a new timing set in it, I doubt that the chain has stretched/jumped teeth, which points to the distributor.
Good luck!
-Brad
Old Mar 5, 2012 | 11:29 AM
rostronic's Avatar
rostronic
Tried pulling out the distributor this morning when the engine was cold, no luck.
Distributor rotates but doesn't move vertically at all.
Usually slides right out.
Tonight, I'll try some leverage after turning the shaft a little.
Old Mar 6, 2012 | 10:17 PM
rostronic's Avatar
rostronic
Got the truck running, was able to pull the distributor by rotating the crank counterclockwise and pulling up.
Put a back up distributor in, set it to TDC and pointed rotor to #1 and it fired right up.
Going to see what was wrong with the old distributor, pin is still there but maybe sheared and it slips under load.
Jhardy62026
Oct 12, 2017 12:53 PM
backbonejay
Apr 12, 2013 04:31 PM
dogmantra
Oct 4, 2010 12:43 AM
ErrorS
22
Nov 11, 2007 07:16 PM
ErrorS
Oct 16, 2007 12:41 AM
