One wire regulator
One wire regulator
Back with another question. The PO added a F7078 one wire voltage regulator. I already wired to the battery and ran the other wire to the green/red 904 wire for the idiot light.
My main question is I have the black/yellow wire, and a yellow wire from the horn relay that are not wired to anything. Also, the PO removed the voltage regulator. Any ideas on where they need to go to? Thanks
One wire regulator
Thanks for the replies. I will post a picture today, as soon as I figure out how.
The alternator is a stock Ford unit that has the additional one wire regulator added. It is nice to modify some things, but cleaning up other peoples modifications has been a pain. And trust me, I can't believe this thing even ran, or burned to the ground.
on
I see your using one of those mickey mouse one wire setup. One was sent to me when bought a 100 amp alternator. That black wire tees into the red high output on the alternator and go to the regulator terminal. Gee forgot where the yellow hooks into.
You Would be better off going to a 3g 130amp alternator setup get rid of the one wire Mickey mouse wiring mess IMOP
Orich
Orich
on
Get the newest looking one then take and have it tested at your loco box auto parts store.
is what I did
Get the 175 amp fuse and red about 3ft of the power wire most guys buy the after market fuse holder with S&H $15 bucks or make what you get work..see link below
http://www.google.com/aclk?sa=l&ai=C...ckv%3DI7IRTiA8
is what I did
devozoo
1997 - 2003 F150
02-21-2011 06:07 PM
