Electrical question
Old Jan 24, 2012 | 06:48 AM
cheddar89's Avatar
cheddar89
Electrical question
So im about to drop a 302 in a 63 shortbed I was wondering if I just hook it up like the other starter that was originally in it and how to wire the altonator? Do I use the original voltage regulator
Old Jan 24, 2012 | 05:44 PM
spurredon's Avatar
spurredon
What engine was in it? Were you running alternator before?
Old Jan 24, 2012 | 05:59 PM
cheddar89's Avatar
cheddar89
The PO had a 352 in it and just ran a wire from voltage regulator and he said the wires burnt up on him once so I was just wonderin how to do.it right
Old Jan 24, 2012 | 07:12 PM
Jetcopterpilot's Avatar
Jetcopterpilot
You need to wire it according to what you new system is... If you have an ALTERNATOR with an internal regulator, then you want to eliminate the old voltage regulator.... Is your alternator a one wire or three wire alternator... you need to wire accordingly! I have a 352 with a one wire Alternator.. so I have ONE heavy gauge wire running directly to the positive terminal of the battery. A three wire will have a wire to the batt., a wire to the field, and a ground.... so you need to be specific as to what you are installing!
Old Jan 25, 2012 | 03:59 PM
rustywheel68's Avatar
rustywheel68
Do a search for a "1g" alternator, and see if that looks like what you've got.
Old Jan 25, 2012 | 04:43 PM
cheddar89's Avatar
cheddar89
sorry I havent got back to you its been raining here and motor is under the tarp I think its the three wire plug tho
atlanta1020
May 5, 2015 07:29 PM
gusso
Electrical Systems/Wiring
Jul 10, 2010 12:02 PM
tom1979
Oct 14, 2007 11:06 PM
spide4x4
Sep 8, 2006 02:12 PM
SteV8e
15
Apr 7, 2006 04:57 PM
