83 f150 upgrade recommendations??
Old 04-14-2016, 09:38 PM
Kwill's Avatar
Kwill
Kwill is offline
83 4.9/300. upgrades already done; cables, battery, plugs, wires, rotors, pads, 4 inch rough country lift, inner and outer tie rods, bearings all they way around, wheels, tires, custom drive shafts, brake booster, master cylinder, new clutch, and several others.
wandering what upgrades you would do for fuel efficiency and reliability? Doing burgeon steering shaft this week also already put in redhead gear box. Truck still has stock single barrel carb. Lets talk performance upgrades? No cheap parts on this truck
Old 04-15-2016, 07:53 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
Your truck looks very good! As far as reliability and fuel efficiency goes, it is hard to beat the stock 300 six cylinder engine.
Old 04-15-2016, 08:08 AM
nuknuk's Avatar
nuknuk
nuknuk is offline
what size tires, 33 or 35's? Good looking truck. If you feel your carb needs changing out, I would go back with a brand new one. Is Weber the stock brand of the carb? I had to replace my fuel tank due to rust in it, so check that. I went ahead and replaced everything new on my fuel system and moved the fuel filter up under the hood between the fuel pump and carb, with just an inline clear filter. Just makes it easier to change and check.
Old 04-15-2016, 08:14 AM
nuknuk's Avatar
nuknuk
nuknuk is offline
Also a rebuild on those drum brakes in the rear might be a good idea, if you haven't already. I replaced my front calibers as well and brake lines. Can always upgrade that exhaust.
Old 04-15-2016, 10:00 AM
Kwill's Avatar
Kwill
Kwill is offline
I am running 35's on it. Its a daily driver for the moment so I am somewhat satisfied with the look and stance of them. However when it goes back to a weekend toy it will probably be on at least 38's.
Don't really know much about carbs except its the stock single barrel. Didn't know if there was a more suitable upgrade considering theres a lot more out there then there was when the truck was manufactured? Forgot to list the fuel tank is new put it in 2012. Good recommendation about the rear drums. This is on the list. Also the truck has flow master duals. Heres a pic of that and the interior. Its a little dirty has gotten its weekly detail
Old 04-15-2016, 11:07 AM
LARIAT 85's Avatar
LARIAT 85
LARIAT 85 is offline
Your truck looks GREAT, Kwill!
I have to agree with 1986F150six: it is hard to beat the stock 300 six cylinder engine.
For reliability, I would keep the engine stock. Make sure your thermostatic hot air choke and thermostatic air cleaner is hooked up and working correctly, and run MOTORCRAFT plugs and wires, and a MOTORCRAFT ignition module. OEM Motorcraft parts are much better than any of the aftermarket junk out there.
For performance, I would go with the Offenhouser intake manifold and a Holley 390 CFM 4V carburetor along with 1987 and later EFI exhaust manifolds, Then, get your distributor re-curved to take advantage of the mods, as the stock ignition curve is set up for emissions and economy.
Old 04-16-2016, 07:32 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,726 Likes on 1,396 Posts
Looks like you need new door panels.
cdubb79w
25
04-29-2019 11:41 PM
bluF150
11-08-2017 01:36 PM
sphen87
39
01-06-2012 12:32 AM
irishff11
07-11-2011 02:27 PM
drfelgood5
10-16-2008 10:45 AM
Quick Reply: 83 f150 upgrade recommendations??
