Stock Fuel System?
Old Jul 11, 2011 | 09:29 AM
irishff11's Avatar
irishff11
Stock Fuel System?
I have a 1985 F150 that I am installing a 302 into. I am putting some performance parts onto it like a 670cfm 4bbl carb and intake. I am trying to figure out if the stock fuel system will supply enough fuel to the carb to function??
Old Jul 11, 2011 | 10:22 AM
Greyf100's Avatar
Greyf100
Did the truck originally have fuel injection, or was it carb to start with? Unless you are going to wind it up past 6,000 RPM a 600CFM 4v should be enough.
Old Jul 11, 2011 | 10:33 AM
irishff11's Avatar
irishff11
It originally had a 300 w/carb. Just moving to the v8 with a 4bbl 670 from holley and want to make sure that it will have get enough fuel supply.
Old Jul 11, 2011 | 12:59 PM
Franklin2's Avatar
Franklin2
You will have plenty of fuel. The stock system supplied 351w's and some 460's also.
Old Jul 11, 2011 | 02:27 PM
Gary Lewis's Avatar
Gary Lewis
X2. You won't have any problem with supplying enough fuel. The only prob might be over-carburetion, but I'm assuming the 670 is vacuum secondary and that should work.
