Charging
Charging
Alright fellas in need of your assistance again, my 1988 f250 7.3 has a charging issue. So to start the battery were dead, replaced those and worked fine but no charge, the battery power to alternator was corroded and broke fixed that with a 30amp circuit breaker and still no charge, pulled the regulator and full fielded alternator by jumping a and f with regulator unplugged, 12.7 volts running, well took alternator to part house and got it tested, it passed 3 times, so for now I got a voltage regulator to put on it and see, anyone else got other suggestions. I'll update in about an hour how regulator worked
Instead of running in circles why not upgrade,
https://www.ford-trucks.com/forums/1...3-92-idis.html
A lot of people like the 3G, but the 1G works just fine as far as I'm concerned. Just check all the wiring. Regulators are the weak point with these alternators, and make very sure your grounds are good(I'd run a wire from the ground on the alternator to the case of the regulator).
As for the rest of the wiring:
That should get you started.
Looking there, I'd check for 12V at the "I" terminal on the regulator with the key on. It's supposed to come through the bulb or resistor shown, and if there isn't any power there, the alternator will not work.
This is probably the same reason shorting the two terminals on the alternator did not work -- these aren't self-exciting; you need a bit of power to get the process started.
Note that if you have issues with the I terminal and need to get power to it, don't run a wire directly from the battery or ignition - run it through a small 12V bulb. If not, the regulator and alternator will get hot when the engine is /not/ running.
Received 3,110 Likes
on
on
hoxiii
12-03-2006 05:56 PM
