Copper Anti Seize
Old 02-25-2016, 06:09 PM
silverbullet6oh's Avatar
silverbullet6oh
silverbullet6oh is offline
Copper Anti Seize
How long does the Copper anti seize work on the exhaust side of the turbo before needing to be applied again?
Thanks - P
Old 02-25-2016, 07:36 PM
Per4mance's Avatar
Per4mance
Per4mance is offline
I'm not sure, but I think you are supposed to use nickle based anti seize.
Old 02-25-2016, 08:07 PM
silverbullet6oh
Yeah, I saw that a lot of people use nickel based rated at 2400 degrees and some use Copper based. I know the copper is rated to 1800 degrees. I'm not worried about that.
Old 02-25-2016, 11:23 PM
run6.0run's Avatar
run6.0run
run6.0run is offline
I assemble them dry and clean
Old 02-26-2016, 12:34 AM
Thor'sHammer's Avatar
Thor'sHammer
Thor'sHammer is offline
I always use copper. Have never had a truck returned, and my personal truck has been going for quite awhile on a coat I put on it. I used to use nickel based AS, but it seems to dry out in the housing and cause the unison ring to stick.
Old 02-26-2016, 05:30 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Me also, and I've never had an issue.
Old 02-26-2016, 06:31 AM
jsm180's Avatar
jsm180
jsm180 is offline
Any anti seize exposed to exhaust flow will be gone in a few hours running time and the burnt residue may cause problems down the road.
Old 02-26-2016, 09:24 AM
silverbullet6oh
If that's the case, then whats the point to the 1800 degree rating?
Old 02-26-2016, 09:27 AM
silverbullet6oh
I think my issue is that I used the same unison ring that had etching where the vanes are, and it is making the turbo stick, again.
I ran it dry the first time, but then I ordered my new unison ring, and thought that it couldn't hurt to put some copper anti seize in there too. Between knowing the unison ring has ecthing, and my EBP senor being bad (ordered) I will soon get this figured out.
Its all so confusing, everybody does it different, and watching Diesel Tech Ron, he is pretty liberal with the anti seize.
Old 02-27-2016, 01:41 AM
run6.0run's Avatar
run6.0run
My personal truck has a powermax I put on about 460k mi ago,, cleaned it 250k ago and assembled it dry. Never had a problem.
Old 02-27-2016, 03:42 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
One has to ask, Is the reason that they spec nickel is compatibly with the
turbine wheel. Also there should be some dry metal left behind after the
exhaust burns away the grease carrier that the anti-size is made with.
Who knows it could be a small change that you would only see with an
electron microscope. So really just pick you poison.
Sean <BR>
6.0L Tech Folder
xaviar
05-19-2015 04:57 PM
93truck
05-08-2014 10:12 AM
joe blow
03-25-2011 05:06 PM
ChunderDownUnder
06-23-2009 03:30 AM
Turbodiesel600
06-20-2007 12:43 PM
Quick Reply: Copper Anti Seize
