Does anyone know where this connects? I have been looking for about an hour can 't seem to find it, it Y's off of the master cylinder line under the brake fluid bottle....driver side
Looks like ebp sensor is on top of line, I have no idea what it is one half of that wire clips into housing under brake fluid the other half is this plug
Awwwweeeeesome, I don't have the factory box installed so it doesn't plug into anything, explains why I couldn't find it......thank you guys really appreciate it!
Also depending on which air filter you are running you may want to consider putting the OEM unit back in before you have turbo problems. There has been much written about aftermarket versus OEM on the internet and I have personally seen 2 dusted turbos on trucks that ran one of the better(?) air filters. I ran a S&B on mine for a while but got tired of having to service it so often and put the original back in.
I am running an Injen power flow dry cleanable filter, haven't had any turbo issues so far, also running archoil on oil and fuel side with T6
