SLIDING REAR WINDOW (need help on how to replace n wire it)
HI need some help from you guys,i'm in with the rear sliding window swap from manual to electric,i have a 2004 F250 SD i want to know if i need to take off the rear seat and also need the wiring diagram to make it open and close,i think that the wire harness have the cables but i need to know which are the cables that runs from rear to dash.thanks for the help in advance
I more than likely have the info you need. But I need to know the
year of the donor truck you got the parts from.
I post the PDFs on how to remove and install for your o4 and for the
year that the parts came from.
On the seats. You might find it less of a pain if they are out of the way
plus you will have to run some wires.
I'll check on Monday for a replay and then post the files later after I get the info.
Merry Christmas
Sean
6.0L Tech Folder
Merry Christmas
Sean
6.0L Tech Folder
Merry Christmas
Sean
6.0L Tech Folder
Merry Christmas
Sean
6.0L Tech Folder
Mykelseychristine
Washington Chapter
12-29-2016 09:50 PM
