SLIDING REAR WINDOW (need help on how to replace n wire it)
HI need some help from you guys,i'm in with the rear sliding window swap from manual to electric,i have a :oval 2004 F250 SD i want to know if i need to take off the rear seat and also need the wiring diagram to make it open and close,i think that the wire harness have the cables but i need to know which are the cables that runs from rear to dash.thanks for the help in advance:-jammin:-X06
I more than likely have the info you need. But I need to know the
year of the donor truck you got the parts from. I post the PDFs on how to remove and install for your o4 and for the year that the parts came from. On the seats. You might find it less of a pain if they are out of the way plus you will have to run some wires. I'll check on Monday for a replay and then post the files later after I get the info. Merry Christmas Sean https://cimg0.ibsrv.net/gimg/www.for...455b8d603e.gif 6.0L Tech Folder :oval |
Originally Posted by Yahiko
(Post 15881272)
If I were you I would stick with the manual.every power one I have saw the cables break then you will be like most I have seen including myself running a screw down the track keeping it shut making it completely in- operable.
Originally Posted by NELFLOW
(Post 15881752)
Hi,te one i'm going to install is already out of the donnor truck what i need is the procces to remove mine and the wires i need to run,where they are going to connect and if i need a motor to open and close the new window.:-X22
(Post 15882553)
I still need to know the year of the donor.
(Post 15883521)
How can i figure out if it is already out of the truck? :-huh
Originally Posted by 04badford
(Post 15884024)
Do you see any parts numbers on it?
