2002 Explorer no 4x4 lights and 4x4 does nothing
I have several posts on this but no answer fixes my problem. The 4x4 lights do not come on. I have check all fuses. I have replaced my module still nothing. I guess I could try another module but dam I am really at a dead end before I have to take it to Ford dealer and get hosed. Any suggestions would help thanks,
I have not worked on the 2002 EXP 4 x 4, but on the F150 there is a shift motor bolted to the side of the transmission transfer case.......... standard test is to remove the motor unit, set on the floor with the electrical plug attached, and try to operate from the dash ****.. If nothing, test for voltage on the wire to the motor. ....... should have voltage if all fuses were checked.
Silver-bullet1
06-05-2017 12:17 PM
elkkiller34
1999 to 2016 Super Duty
12-11-2016 12:50 AM
