Knock after injectors replaced
I just replaced all 8 injectors in my 01 F550 with remans from FFD. I have noticed a constant knock at idle but truck runs great. Blowby has no pressure behind it, truck does not smoke. Does this sound like a problem unrelated to an injector?
It did not make this noise before replacing the injectors
Any help is greatly appreciated!
Sometimes injectors are noisy, sometimes air gets in oil and it makes a knock. I didn't hear anything that my truck hasn't done for the last 80K miles - but it does come and go. Scott's truck makes the same noise.
The Sound of Da Big Stink - YouTube
I was hoping one of the injectors was loose but i guess i was lucky. Could the noise be tied to oil brand/synthetic/weight?
I have found synthetic (any brand) to be a little noisier than dead dinos - but that's primarily because it's easier to cavitate the lighter oil if air is introduced. I believe my truck has a bad seal on the oil pick-up tube, and accelerating up a step grade results in a lot of knock for a while.
They are stock splits with the long lead in #8. I was also trying to fix a long crank to start by replacing injectors, ipr, icp, hpop but no luck. If i turn key off then restart right away it fires right back up but if i wait a few minutes it takes an extra second to start. Oil pressure on dash shows almost immediately.
caterpillar
07-24-2007 09:47 PM
Jerrod
02-20-2006 07:33 AM
