Cruise control
Old 11-24-2015, 09:42 PM
Macrobb's Avatar
Macrobb
Macrobb is offline
Originally Posted by Ford F834
Thanks, mine is definitely missing the cruise sensor then. More junkyard homework to fix the PO's hackwork. I will send you a PM about your GVOD computer delete... I am curious about this but I don't want to hijack this thread any worse than I already have.
If it's a newer model(not sure when they changes), it could be using the ABS sensor?
I'm not sure why they didn't use that in the first place, but they didn't on my 88.
As far as GVOD delete... all you need to do is get 12V and ground to the two GVOD solenoid terminals when you want it active. So literally just switched power to one terminal, ground to the other.
You'll find that with the switch on, and it engaged it will /stay/ engaged, even if you stop. If it's not engaged when you stop, it won't engage(has to be spinning to engage). It will clunk in once you start(not recommended).
You also have to make sure the switch is /off/ when in reverse. It can try to engage going in reverse and will make rubbing/grinding sounds and wear the clutch inside. This is something the computer prevented you from doing.
Franken-Truck
17
12-25-2011 03:11 PM
lowcountry
Escape & Escape Hybrid
10-16-2009 09:25 AM
willym
1999 to 2016 Super Duty
13
11-06-2005 01:07 AM
redbull660
04-26-2004 07:39 AM
dusty1
2004 - 2008 F150
15
03-11-2004 04:54 AM
Quick Reply: Cruise control
