1988 F350 Temp gauge & coolant temp sensor
Old 11-15-2015, 03:55 PM
mwilliams0326's Avatar
mwilliams0326
mwilliams0326 is offline
My temp gauge is only working occasionally so I replace what I thought was the coolant temp sensor on my 1988 F350 with a 7.5L 460. It has a plastic connector coming off of it with a green and black wire. I'm reading in other forums that it should only be a single wire (red/white stripe). The sensor I replaced is to the right behind the distributor. The gauge is still not working. I was wondering if somehow I have replaced the wrong sensor. Also it shows my wiring from this sensor going back to the computer so what wire actually goes to the gauge? Any help is greatly appreciated!
Old 11-15-2015, 04:32 PM
Conanski's Avatar
Conanski
Conanski is offline
Yeah it's a little single wire thing about the size of a nickle near the #5 injector on the V8 trucks and down on the side of the block for the I6.
Old 11-15-2015, 04:42 PM
mwilliams0326
Is this it? It does not have a single white wire.
Old 11-15-2015, 04:44 PM
mwilliams0326
Picture above is the sensor i replaced. It did not have a single white wire.
Old 11-15-2015, 05:21 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
You are confusing the SENSOR for the computer with the SENDER for the gauge.
Old 11-15-2015, 05:59 PM
mwilliams0326
Ok great! So where is the sender for the gauge? I've looked everywhere. Even my shop manual is showing this one as the one for the gauge so I'm lost.
Old 11-15-2015, 06:07 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Try this...
https://www.ford-trucks.com/forums/1161136-1989-f250-xlt-460-temp-sensor-sender-switch-location-for-dash-coolant-temperature-gauge.html
Old 11-15-2015, 06:08 PM
88XLTLariat's Avatar
88XLTLariat
88XLTLariat is offline
Old 11-15-2015, 07:24 PM
subford's Avatar
subford
subford is offline
The temp sender for the dash gauge is near the end of the injector manifold on the passenger side on the 460.
Old 11-16-2015, 09:02 AM
mwilliams0326
Got it! You guys are awesome. Thank you much!!!
bellssn690
04-01-2016 05:23 AM
Commander_Chaos
02-05-2014 08:34 PM
RebusCom
09-21-2013 04:28 PM
paulwjax
07-11-2009 06:37 PM
OLDBLUE69
03-02-2008 11:49 AM
Quick Reply: 1988 F350 Temp gauge & coolant temp sensor
