Temperature Gauge/Sender not working
Old Nov 27, 2011 | 06:52 PM
Will Chiello's Avatar
Will Chiello
I have a 1988 F150 with a 302. What I need to know is the location of BOTH temperature sending units. I have changed the one right behind the thermostat housing (the one with 2 wires). The other one that has been mentioned, is the one that I'm not sure of. The two places that I think could be the other sender are between the #2 and #4 injectors (driver's side 2 front cylinders) on the intake manifold w/2 wires or the other place at the left front corner of the intake manifold (driver's side) w/1 wire. If someone could help me with this, I would really appreciate it. If you may have a picture or a diagram, that would probably help alot. Thanks!
Old Nov 27, 2011 | 10:23 PM
wagonerkl's Avatar
wagonerkl
Okay, I hate it when guys who do not know, try to answer. At the risk of now being "one of those guys" but only because no one else has answered, here we go.
I have a '91 EFI with the 351W which is similar to but obviously not the same as your 302. The Temerature Sending Unit (one wire) is very close to the Temperature Sensor (two wires). Mine was right behind and to the left (driver's side) of the distibutor. You have to look close as it is sort of hiding.
Hope this helps;let me know.
Old Nov 27, 2011 | 10:54 PM
rla2005's Avatar
rla2005
A photo from our friend Bill aka subford:
Old Nov 28, 2011 | 04:08 PM
Will Chiello
Thank you guys very much.
Old Nov 28, 2011 | 06:44 PM
toby tough's Avatar
toby tough
I also am not sure but the one on the intake is the intake air temp sensor.
Old Nov 28, 2011 | 07:22 PM
rla2005's Avatar
rla2005
You are correct:
courtesy of Paul Conanski
j_blueridge
Mar 18, 2010 03:42 PM
RedRooster77
1978 - 1996 Big Bronco
Apr 14, 2007 10:54 PM
B Dobz
Feb 14, 2007 09:32 PM
craigP
May 3, 2004 08:42 PM
v_mark
Jul 5, 2003 06:25 PM
