ARP BOLTS
Old 11-13-2015, 10:22 PM
fabieber's Avatar
fabieber
fabieber is offline
ARP BOLTS
I am trying to find ARP bolts which seem to be the only bolts I can use to put Ramhorns exhausts on my '55 / 239 Y Block. I have found several web sites that sell kits for various engines but none that fit my truck. Should this be a hardware store item where I can buy 14 bolts I need.
By the way, the size I need is 3/8 by 1 1/2" x 16 threads per inch.
I cannot get a socket over the bolts. I have found some allen head bolts that I could use but the heads are so small I'm concerned they may not be a good idea.
Old 11-13-2015, 10:56 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
John Mummert does not list an ARP bolt for his manifolds HOME Y
I would contact him to see what he recommends.
Old 11-13-2015, 11:33 PM
1950FordF1's Avatar
1950FordF1
1950FordF1 is offline
If you can't find what you need call them direct. I don't use ARP often but have ordered direct before.
ARP | The Official Web Site
Old 11-14-2015, 12:06 AM
eman92082's Avatar
eman92082
eman92082 is offline
I used ARP exclusively on my engine purchased from Summit. There are sets for common applications but if need be, you can buy bolts and such individually.
Old 11-14-2015, 12:09 AM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,451 Likes on 1,398 Posts
I would try to avoid basic hardware store bolts for exhaust manifolds. You want something that will take the heat cycling involved. The box stores offer some pretty low grade hardware that they sell for outrageous prices, especially for what it is. See if there's a real bolt store near you. There's a Tacoma Screw in Portland that could probably be helpful.
I know there's several places in my area that sell top quality hardware for much less than you'd think it would be, and they don't mind selling 25 cents worth of nuts at a time. I would think there would be at least that many in your neighborhood.
Old 11-14-2015, 05:49 AM
fatfenders's Avatar
fatfenders
fatfenders is offline
I think you will find what you need on page 87 of the ARP catalog posted. They have a reduced head fastener in bulk packages of five bolts. As 52 Merc says, I too would avoid hardware store fasteners for exhaust manifolds. They would be fine for temporary use but normally have a full sized head anyway.
Old 11-14-2015, 08:15 AM
artscott61's Avatar
artscott61
artscott61 is offline
Try a capscrew called 12 point counterbore. they have a tensile strength of arounf 170,000 psi they are for some tight spots.
Old 11-14-2015, 09:54 AM
Nicholas+'s Avatar
Nicholas+
Nicholas+ is offline
What I usually do is go to the ARP website (the link that 1950FordF1 posted). Then find the bolts you want and copy the part number. Google that number and you will see them for sale at various vendors usually cheaper than the ARP site. This is what I came up with ....ARP 652-1500, ARP Bulk Standard Thread Chromemoly Bolts | ARP
Old 11-14-2015, 10:18 PM
fabieber's Avatar
fabieber
fabieber is offline
Thank you gentlemen. I did buy grade 8 bolts at a local hardware store but will go with the Arp bolts as you all recommend.
Groundpounder0331
07-14-2015 12:24 PM
TexasDiesel97
05-22-2012 05:58 AM
Restoman2
03-18-2011 12:40 PM
spidermonkey
04-24-2008 12:16 PM
51PanelMan
04-24-2005 06:52 PM
Quick Reply: ARP BOLTS
