headers on a 460 in a 56 f100
Received 4,131 Likes
on
I can't say for sure but you could check with Lokar, they have a cable type dip stick which is in a stainless steel sheath tubing that should work. I have them for my transmission and engine oil dip sticks on my sbc in my panel.
http://www.lokar.com/product-pgs/eng...dipsticks.html
I've got the Sandersons on mine( 460, rear sump, Mustang 2 front). The Lokar is a no go, as the bottom fitting is just too bulky. The dipstick was a pain, basically, I massaged the fitting in the sump pan, very carefully re shaped the tube to clear the headers, and welded on a new bracket to pick up on a header bolt. Obviously I took the old bracket off. I could offer you an image, but I suspect it won't help, as I can't get into the pan end to show you, now the headers are on. I couldn't get the retaining clip in, so have sealed it using a mastic. It is very solidly mounted and expect it to work and hopefully will. Engine not yet run.
Time is cruel! I forgot to add, I also moved the flange on that side and put in a tight 90 degree elbow. I also cut through the exhaust almost entirely, to move the flange further away from the dipstick point, and re-filled with a panel. I'll try and attach a couple of images.
F3fitty
03-21-2022 06:50 AM
superman64011
06-29-2019 07:09 PM
hwyhogg
09-08-2016 09:19 PM
jniolon
09-05-2016 12:00 PM
