I can only assume it ran before " rebuilding" the fuel bowl . What exactly does that mean ? If you have fuel pressure at the heads , its not the fuel delivery system . Even at 20 Lbs , it will start .
I replaced all the o rings in the fuel bowl and fpr
You ever get that truck started? I stumbled across this thread. Look at post #4.
Thanks for the help, but the guy who owned the truck before be pulled the element and the wireing out before he sold it to me, I'm starting to wonder if it's an hpo issue or possibly an injector issue
I got it running! And I feel like a royal tool! Apparently, I never plugged the ipr back in after the rebuild. ..... so I plugged that back in and got smoke at the tail pipe, but it still wouldn't fire, so after using that flow chart above, I tested the glow plug controller, found it to be bad, so I replaced it, and now (after a little initial rough running) she runs better than ever!
