help my 95 won't start
Old 11-11-2015, 11:27 PM
screaminseaman3's Avatar
screaminseaman3
screaminseaman3 is offline
Originally Posted by Action4478
I can only assume it ran before " rebuilding" the fuel bowl . What exactly does that mean ? If you have fuel pressure at the heads , its not the fuel delivery system . Even at 20 Lbs , it will start .
I replaced all the o rings in the fuel bowl and fpr
Old 11-11-2015, 11:37 PM
screaminseaman3
Originally Posted by sean9049
check to make sure the IPR is plugged in and locked with the little metal tab that flips over it.
It is, and I even triedstarting with ipr unplugged to see if it was stuck
Old 11-12-2015, 04:56 PM
finallyo3gt's Avatar
finallyo3gt
finallyo3gt is offline
You ever get that truck started? I stumbled across this thread. Look at post #4.
Old 11-12-2015, 06:18 PM
screaminseaman3
Thanks for the help, but the guy who owned the truck before be pulled the element and the wireing out before he sold it to me, I'm starting to wonder if it's an hpo issue or possibly an injector issue
Old 11-12-2015, 06:23 PM
finallyo3gt
Rats... I was hoping that was going to help. Good luck man.
Old 11-20-2015, 06:49 PM
screaminseaman3
ongoing
So I now have replaced both valve cover gaskets, and re did all the accompanying wireing, trying to start again
Old 11-23-2015, 08:45 PM
finallyo3gt
Well post #4 happened to me this morning.....
Old 11-23-2015, 10:20 PM
screaminseaman3
Finally!
I got it running! And I feel like a royal tool! Apparently, I never plugged the ipr back in after the rebuild. ..... so I plugged that back in and got smoke at the tail pipe, but it still wouldn't fire, so after using that flow chart above, I tested the glow plug controller, found it to be bad, so I replaced it, and now (after a little initial rough running) she runs better than ever!
Old 11-24-2015, 07:23 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
Awesome. Don't worry. We all feel like tools once in a while. Even the ones that won't admit to it
Old 11-24-2015, 07:27 AM
finallyo3gt
Yup, been there...
mpbpulaski
02-16-2012 03:56 PM
mesimpson66
18
07-26-2011 12:29 PM
IceboxFX
11-21-2008 05:10 PM
tecmutant
10-20-2008 06:37 PM
wiyo120
46
10-15-2007 06:34 PM
Quick Reply: help my 95 won't start
