1978 - 1996 Big Bronco
headlights "
Old 10-11-2015, 11:23 PM
1986Bronco's Avatar
1986Bronco
1986Bronco is offline
headlights "
Hi Guys, I have a 1986 Ford Bronco full size 302 yada yada..
The other night we were coming home and the headlights went out then came back on, then went out again and came back on again
Has anyone out there in Bronco Land ever had this happen"??????
Old 10-12-2015, 12:55 PM
1985 Bronco's Avatar
1985 Bronco
1985 Bronco is offline
Welcome to FTE 1986Bronco! I know that 80-86 trucks have a problem where the headlight switch can burn out. LMC makes a harness to fix that, or you can make your own. There should be a "how to" in the bullnose forum. Take a look at the switch, and let us know.
Old 10-15-2015, 09:03 AM
brocluno's Avatar
brocluno
brocluno is offline
Might also be the hi/low beam foot switch. Turn on the lights and wiggle the foot switch and see what happens...
Old 10-15-2015, 09:58 AM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
I've had this happen from both of the above mentioned issues.
The high beam switch is the easier and cheaper of the two fixes. They cost around $5 - $10 and take 15 minutes to switch out. Two screws hold it to the floor.
Amazon.com: Standard Motor Products DS70T Dimmer Switch: Automotive Amazon.com: Standard Motor Products DS70T Dimmer Switch: Automotive
The headlight switch requires removing the dash, which can be tricky. The hardest part is actually removing the ***** from the headlight and windshield washer switches. There's a tiny tab on the back (location is marked by a notch on the back of the **** itself). You need to get a little hook of some kind to press it while you pull on the **** to get them off. Afterward, replacing the switch is plug and play.
Amazon.com: Standard Motor Products DS-219T Headlight Switch: Automotive Amazon.com: Standard Motor Products DS-219T Headlight Switch: Automotive
Both are inexpensive enough that'd I'd replace both. Your headlights going out is not a good thing. Been there, done that, in the middle of nowhere at 2am during a new moon... You need your headlights!
Jose A.
Aerostar
11-24-2015 10:40 AM
Eddillard79
07-26-2015 02:41 PM
1979Ford33
08-19-2014 06:38 PM
eandaauto
22
08-22-2004 12:18 PM
Quick Reply: headlights "
