Headlights Going Crazy
Old Jul 16, 2004 | 01:38 PM
eandaauto's Avatar
eandaauto
I have a 1969 F250 and I have been having problems with my headlights. They will not stay on - When I turn them on they stay on for around 1-2 minutes and then they start flashing on and off randomely. I don't care much for wiring and don't want to start messing with it until I know what I should be looking for. Any ideas?
Old Jul 16, 2004 | 03:17 PM
Freightrain's Avatar
Freightrain
Sounds like headlight switch. It gets hot, then loses contact. Been there.
Pretty typical if all original still.
If it is not the headlight switch, then try the bright switch on the floor. They have a tendency to get corroded and lose contact. When the lights starting blinking, kick the switch a few times and see if it makes a difference. Try switch LO to HI beams and see if it still blinks. If so, then it's the headlight switch. If it ceases, then it's the bright switch.
Old Jul 16, 2004 | 08:56 PM
bigric's Avatar
bigric
Ditto on the switch. Mine started doing this on a rural highway at about 1 AM right after somebody passed me. I think I scared the hell out of him as we were the only two vehicles in sight for miles.
Old Jul 17, 2004 | 02:11 PM
'Ol Beige's Avatar
'Ol Beige
yep . headlight and dimmer switches are famous for problems.
has happened to me..............
Old Jul 18, 2004 | 06:53 PM
Faithful Old Road Dog's Avatar
The few times it happened to me turned out to be the halogen lamps I just put in (drawing more juice) and the other time was a hot wire from the trailer hook up grounding out on the bumper.
Old Jul 19, 2004 | 01:02 AM
Mike W's Avatar
Mike W
Also check the ground wire for the headlamps.
Old Jul 19, 2004 | 01:54 AM
To_Fast_To_Furious's Avatar
To_Fast_To_Furious
Check the rest of your light like your interior light, if it starts diming high then low it can be your alternator,battery or your engine cold be ideling to low.
When mine was doing that it was because the engine was ideling to low and was not turning the alternator enough, also make sure your belts is not loose to your alternator or its not worn or cracked.
Old Jul 19, 2004 | 05:23 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
You can check the dimmer switch by removing the switch and using a jumper wire. Make sure you use the low beams. If they no longer blink, change the dimmer switch. If they still "blink" Change the Headlamp switch. There is a circut breaker in the headlight switch. When the switch gets old, the breaker which is a heat sensitive spring type, gets weak and breaks the circut.
It flashes on and off because it keeps cooling off and re-heating.
If you replace the headlamp switch and it still does it, check your wiring cause there may be a short.
Old Jul 19, 2004 | 09:44 AM
fordification's Avatar
fordification
I have exactly the same problem. For me, it's running to much current through a common ground. Atleast, that's what I think the problem is. Everytime I hook up the lights for my autometer guages, my headlights start flashing.
I still have to try another ground to see if it's the problem.
Old Jul 19, 2004 | 10:45 AM
67and71_Carl's Avatar
67and71_Carl
Guys,
This problem might be associated with adding new headlights that use more current than the originals. This, in turn, causes the circuit breaker to cycle--just like it's supposed to. This causes the on and off phenomenon of the lights. The answer is to add relays. There are numerous posts about this and (Ken, help me out here) a Technical Instruction somewhere.
Old Jul 19, 2004 | 11:23 AM
orich's Avatar
orich
Well, I guess i'll add my 2 cents. My troubles, was a dirty connection plug under the hood where the cab-wiring connects to the fender wiring for the head lights. Cleaned and a shot of WD-40 or dielectric grease. Also that circuit breaker inside cab next to the glove box on some models..
orich
Mil1ion's Avatar
Mil1ion
Go here .
https://www.ford-trucks.com/articles/index.html
& look for the "Whiter Whites Brighter Brights" tech article
Old Jul 19, 2004 | 12:23 PM
fordification
Originally Posted by Mil1ion
Go here .
Yikes!
God I hate wiring.
Old Aug 19, 2004 | 12:23 AM
Mr.Majestyk's Avatar
Mr.Majestyk
Replacing Headlight Switch
Hello , my headlights started flashing eratically last night . I assume its the switch as they flash with both the low beams and high beams . Can someone tell me the procedure for changing the headlight switch ? I get a little cautious when it comes to electrical items. Thank you very much.
Old Aug 19, 2004 | 12:51 AM
orich's Avatar
orich
That does not sound like the dash light switch to me. Sound more like your light relay is doing when it's over loaded or it's bad. Most 69thr70 I've seen there up next to the glove box under the dash....my 2 cents
orich
