Reason headlights not working
Old Jul 24, 2015 | 07:21 PM
Eddillard79's Avatar
Eddillard79
I need some suggestions. I have a 85' F350 w460. My headlights stopped working on me a few days ago. All the marker, taillights, and turn signals work. I checked my fuses, and I replaced the dimmer switch (high/low beam). It didn't help. Do I need to try replacing my headlight switch? Can it be as simple as both headlight bulbs going out at the same time?
Old Jul 24, 2015 | 07:36 PM
Gary Lewis's Avatar
Gary Lewis
Not likely to be both headlights going out at the same time. Much more likely to be the wire leading to the switch, or the switch itself. The wire is a known failure point, so look at the wires to/from the switch for melting, burning, etc.
Old Jul 24, 2015 | 07:45 PM
Eddillard79
Ok thanks. I'll try that tomorrow & I'll give an update
Old Jul 24, 2015 | 09:57 PM
Franklin2's Avatar
Franklin2
An easy thing to do is get a testlight or voltmeter and then pull the new dimmer switch back off the floor. Pull the connector out just a little bit so you can probe the terminals, and then turn the headlight switch on. If you have voltage down at the dimmer switch, you know the headlight switch is working. If you don't, you know the problem is at the headlight switch.
Old Jul 25, 2015 | 05:54 PM
Eddillard79
Ok I found the problem. It's a few melted wires going into my dimmer switch.
My question now is, can I just cut & splice where the wires are melted at? Or do I have to completely re-run the wires from where ever they came from?
Old Jul 25, 2015 | 07:29 PM
Gary Lewis's Avatar
Gary Lewis
You can cut and splice, assuming there isn't damage elsewhere. BUT, you have to fix whatever caused the problem first, or it'll come right back. If the problem was a bad dimmer switch or connections thereunto, replacing the switch and connectors, along with replacing the wire that is melted, should do it.
Old Jul 26, 2015 | 02:41 PM
bcamill's Avatar
bcamill
Check the dimmer switch on the floor. If the connector there becomes loose, then all markers will work, but no headlights.
Jose A.
Aerostar
Nov 24, 2015 10:40 AM
1979Ford33
Aug 19, 2014 06:38 PM
fmansfield444
Aerostar
19
Jun 23, 2011 03:34 PM
blucollar4xford
Electrical Systems/Wiring
Jan 8, 2011 08:40 AM
co298s
1997 - 2003 F150
Jan 10, 2004 11:47 PM
