under load miss
Old 10-04-2015, 05:06 PM
samthelion's Avatar
samthelion
samthelion is offline
Question under load miss
2000 Explorer Sport 4.0. I just did the heads, valves, decked, proofed. New wires, plugs. Followed the procedure to the letter. First two starts were a bit touchy, but now starts fine and purrs like a kitten at idle. The problem; under load it acts like it drops a cylinder. Any ideas? Bad plug, bad wire, fouled injector? This thing is driving me nuts. Thanks.
Old 10-04-2015, 06:35 PM
shorod's Avatar
shorod
shorod is offline
Have you checked for pending misfire diagnostic codes?
-Rod
Old 10-04-2015, 08:01 PM
samthelion's Avatar
samthelion
Oh, my.
Not yet. Thanks for the tip.
Old 10-05-2015, 05:50 PM
samthelion's Avatar
samthelion
UPDATE
Talked to my mechanic friend today. He recommended that I scan it for coil pack break down. After fifteen years that is most likely it.
Old 10-05-2015, 07:16 PM
shorod's Avatar
shorod
shorod is offline
And a misfire diagnostic code would point that direction, but if the misfire codes only point to one cylinder, then it may not be a coil issue. Some scan tools can even access the PIDS for Cylinder Misfire Counts so you can see how many misfires are measured by an individual cylinder which can identify a cylinder that is misfiring long before it triggers a diagnostic code.
-Rod
Old 10-09-2015, 03:34 PM
p51man's Avatar
p51man
p51man is offline
Did you install Autolite 764 plugs. they are incorrectly listed for the application and will miss under load. get motorcrafts if so.
Old 10-20-2015, 06:13 PM
samthelion's Avatar
samthelion
No autolites. I use NGK or EEE. I have better luck with both, especially the EEE
Old 10-20-2015, 06:23 PM
Chugalug's Avatar
Chugalug
Chugalug is offline
How much Deck height??
Too much may cause this.
Old 10-21-2015, 01:24 AM
Chugalug's Avatar
Chugalug
Chugalug is offline
A week valve spring can cause this also.
Old 10-26-2015, 05:29 PM
samthelion's Avatar
samthelion
Deck height is within blueprint parameters and valve springs checked out okay.
Thanks, everybody. Its the coil pack.
dziwei
3.8 & 4.2L V6
02-23-2019 01:14 PM
elemakule
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
10-01-2013 12:24 PM
73effie
1983 - 2012 Ranger & B-Series
08-16-2009 12:27 AM
dale88
11-13-2007 07:18 PM
sirondl
07-05-2002 01:36 PM
Quick Reply: under load miss
