P0305/P0316 Codes
Old Nov 27, 2012 | 04:13 PM
elemakule's Avatar
elemakule
P0305/P0316 Codes
On a 2005 Ranger 4.0 V6, 305 & 316 codes indicating cylinder 5 misfire in first 1000 revs. This occurs, obviously, at start up consistently. The truck idles rough but seems to run fine. Spark plugs were replaced. Swapped plug wires between cylinders 4 & 5; code stayed with cylinder 5. Replaced the coil pack; no joy.
Any suggestions? It would be nice to be able to diagnose without spending too much money. The coil pack was $75 for nothing.
Thanks.
Old Oct 1, 2013 | 08:50 AM
dwbaily's Avatar
dwbaily
Thanks.
I know it's been awhile since your post but did you ever get issue figured out? I have same problem with my 03 Explorer Sporttrac 4.0. Changed o2 sensor and that fixed it for around 1000 miles but now same 2 codes reared their ugly heads again this morning.
Old Oct 1, 2013 | 11:26 AM
elemakule's Avatar
elemakule
P0305/P0316 Codes
It turned out to be a bad injector. Replaced the one injector for the reporting cylinder and all is well.
Old Oct 1, 2013 | 12:24 PM
dwbaily's Avatar
dwbaily
Glad you got yours fixed. Maybe they messed one of mine up when they flipped them from the old engine to the new long block. Hmmm.......
Flyfisher98
2004 - 2008 F150
Dec 26, 2017 08:39 AM
sethrich89
1997 - 2003 F150
Jul 23, 2017 11:14 AM
WillFargo
Aug 13, 2011 04:52 PM
broken ford truck
1997 - 2003 F150
Jul 1, 2010 09:19 PM
gyzmo20
Bronco II
Feb 16, 2005 07:06 PM
