Replacing lower radiator hoses
Old 09-26-2015, 12:02 PM
BillM2's Avatar
BillM2
BillM2 is offline
I'll be changing out the lower rad hoses on my 2000 EX. All looks quite straightforward except for the hoses to/from the oil cooler. Someone put the pressure hose clamps with the tabs upwards. Before I go any further, what's the best way to get at and reach those clamps. Does removing the wheel help, for example?
Old 09-26-2015, 05:40 PM
Archion's Avatar
Archion
Archion is offline
Old 09-26-2015, 06:00 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,188 Likes on 816 Posts
I find it easier just to remove the oil cooler, you can also do a flush on the coolant side while its out. Good luck
Old 09-26-2015, 06:17 PM
BillM2's Avatar
BillM2
BillM2 is offline
Originally Posted by Archion
That's actually where they usually are. This is your friend.
Amazon.com: OTC 4525 Cable-Type Flexible Hose Clamp Pliers: Automotive
Thanks! Yes, I've seen this. Advance has the same for a few bucks less. I'd like to save the old hoses as back-up but I may just cut them off close. There may be just enough slack.
Old 09-26-2015, 06:21 PM
BillM2's Avatar
BillM2
BillM2 is offline
I was doing some reading here and it looks like removing the oil cooler is an incredibly difficult, multi-step procedure. I'm working on a V10 gasser. Am I wrong on this?
Old 09-26-2015, 07:29 PM
z31freakify
Its an easy processes
step one take your oil filter out.
Step two find a 14mm hex head insert it where your oil filter bolts on to loosen it up remove qnd wala your done
Old 09-26-2015, 09:17 PM
BigBair's Avatar
BigBair
BigBair is offline
I changed mine a couple weeks after I bought the Ex. The coolant lines going to the oil cooler had been rubbing on the frame and looked like they wouldn't last much longer. I just pulled it up on car ramps and changed them. I believe it took 30-45 minutes of hating life with a pair of channelocks in a very awkward position laying beneath the Ex. If I recall correctly mine were rotated upward also. Whichever position it was seemed like it was a bad position, but ended up being the easiest way to get them back on.
My Ex is leaking a little oil from behind the oil cooler and I have since purchased a new gasket for it. I have been avoiding that job because I thought I would have to deal with the clamps again and the motor mount would need to be removed to take it off. I am not looking forward to that job and may leave it until the leak gets worse.
Good luck!
Old 09-28-2015, 01:18 PM
BillM2's Avatar
BillM2
BillM2 is offline
Good luck!
So is it simply removing the bolts or does it involve removing the mounts to remove the oil cooler. The previous poster thinks it's not too involved and does not require removing the mount.
Old 09-28-2015, 01:44 PM
BigBair's Avatar
BigBair
BigBair is offline
I just looked at the diagram again and to just remove the oil filter adapter you can probably do like he said. If so it should be much easier to get those hose clamps on and off.
Removing the entire oil cooler like I was talking about is supposed to require removing the motor mount. Check out this thread for the diagram-https://www.ford-trucks.com/forums/876424-oil-leak.html
Old 09-28-2015, 03:59 PM
BillM2's Avatar
BillM2
BillM2 is offline
So the adapter is #36 in this diagram?
brian_06328
11-20-2019 08:09 AM
tchad07
1978 - 1996 Big Bronco
02-06-2007 06:22 AM
crittersale
01-05-2005 12:11 PM
ppoel
11-05-2001 10:37 AM
Quick Reply: Replacing lower radiator hoses
