Transmission question - pretty basic.
I don't see that at all.
The delay in engaging when cold is often a drainback valve that is leaking. As mentioned above, check the trans fluid after it's been sitting overnight. Check it BEFORE starting the engine. If it shows overfilled, the torque converter has drained into the pan. The delay is the pump refilling the torque converter.
I have never seen one with symtoms like this be a transmission problem. It's ALWAYS been an engine problem.
Another clue that it isn't the transmission.
I recommend looking harder.
They are not mechanically connected when the torque converter is unlocked, and especially not connected when the trans is in neutral.
Probably not. I'm nearly 100% sure this is an engine problem, not a trans problem.
So my question for you is what kind of damage would you think could happen if a drain back valve went bad and not replaced?
Thank you as always for your input it is much appreciated!!
The problem is you are too astute.
Ford Powerstroke
If the drainback leaks, in my opinion, the only downside is that after it's sat for enough time for the converter to drain you're going to have to idle before the torque converter will allow the truck to move. That's it.
...Rich I have found in working on boats with inboards and I/O's that harmonic vibrations can sometimes feel like a pulse at just the right rpm's. And as odd as this might seem I have had where changing the harmonic balancer cured the problem. I know I have suggested to you before a Fuildampr and I still think it would help with some of the minor issues you are having.
Ford Powerstroke
Ford Powerstroke
As astute as I might be - I need to be more "asstute" to sort out vibrations... my butt makes a lot of mistakes.
