99 f250 v8 with 8 mil codes, 4 bag codes, help??
So i have 8 codes and im not sure if they are all related or not. I figured id post here before i started replacing stuff.
I bought this truck with these 8 codes,
p0113 iat circuit high input
p0118 ect circuit high input
p0340 cam pos. sensor circuit fault
p0705 trans range sensor circuit fault
p0708 trans range sensor circuit high input
p0155 ho2s21 heater circuit fault
p0713 trans fluid temp sensor high input
p1290 cylinder head temp. sensor low input
It also has air bag codes
b1318 low battery voltage at module
b1932 driver airbag high resistance / circuit open
b1884 pad warning lamp in-op.
b1869 airbag warning indicator lamp circuit open
Im certain that i cleared all these codes before but they are back on.
Where should i start? Is there something i should check? Oh and i had replaced a tie rod they was way out of alignment, maybe i messed up the clock spring? And both airbag lamps work.
That is very possible. The light was on when i got the truck. I had to have body work done. Exhaust manifold and brakes fixed. It was dirty inside and door ajar light is on. So i feel it was neglected. Are the listed sensors common to go bad? Also, where are the grounds located on these trucks?
Check the signal return circuit (Gray/Red) from each of the sensors referenced in each code to PCM pin 91. Verify that the signal return circuit has cntinuity to chassis ground. The O2 heater circuit is separate as are all the airbag codes.
The grounds that are most important to the PCM are located back in the corner on the driver's side under the hood hinge, and either up under the center of the instrument panel or in the left side kick panel (depends on productions date).
For the airbags, the ground for that system is behind the left side kick panel.
I checked the IAT with a scanner and with a multimeter and everything checks out. So.. I reset the mil, this time i had to be certain i did it. Drove the truck for a night and mil came back on. This time for front o2 sensor. But i also have a manifold leak so im going to fix that first and see if my o2 sensor values change
I looked for the grounds in left side kick panel come up empty handed. Thats like the lower A-piller correct?
Im probably just going to change the clock spring.
I fixed the manifold leaks and have ZERO exhaust leaks.
i erased the codes and none came back.
But then the p0155 ho2 sensor 1 bank 2 code came back.
I changed the o2 sensor, twice, still came back on. I disconnect the 104 pin pcm harness and probed the wires, the heater wire and the input wire for the pcm and got .6 ohms on each.
As for the other two wires, i dont know how to test them. As ill note, it doesnt appear the input or heater wires are shorted to ground because i checked for cont. between ground and both.
Any help is super appreciated.
