IDI clutch
IDI clutch
I have a 1990 retired U-HAUL E350 with 7.3 IDI and C6. I converted it to a motorhome. I am putting a ZF5, BW1356 or NP205 and Dana 60 on it. I got a donor vehicle drivetrain I believe is a 89. It has a IDI of unknown year. I plan on using the flywheel and resurfacing it. The clutch disc measures 12 1/4". I plan on replacing the clutch disc and pressure plate. I want to know which clutch to purchase. My plans for the motor will be a rebuild, Banks turbo, a slightly better cam and exhaust. It,s in a 9,000 lb rig shaped like a brick, not a hot rod but, still I don't want a clutch that will give out. I'm new to the IDI world so I would love some input from people who know more than I do. I am a machinist by trade so any necessary adapters I can make. Thank you all for your replies.
I have the same driveline setup you have, including 4.10's. Love this clutch. For me there is almost zero gear rollover but each pickup is different.
While you're doing all this I highly suggest filling the ZF with Redline MTL(manual transmission lube). Has friction modifiers that keep the synchros healthy for a LONG time and let's you shift super smooth, even in cold weather. Its night and day to the gear oil some people run. (ZF has a big fat chart of approved lubes and it's staggering how wide the range of stuff is, all the way from 75w gear oil to synthetic ATF)
In the case of our trucks, ATF in both the transfer case and transmission. If you put gear oil in the transfer case, YOU WILL DESTROY IT. In the transmission, I guess it can handle other stuff, but I would still use synthetic ATF, mercon or equivalent.
To prevent/reduce gear rollover noise, add an extra quart to the transmission, through the shift lever hole.
Toyota's run 90w gear oil in aluminum transmissions and transfer cases.
Don't get me wrong, I'm not trying to argue you, just the first thing to pop into my mind.
I will probably use what it calls for as far as oil.
The transfer case I'm still undecided. The BW1356 is chain driven and has rear output slip yoke. NP205 is a much better case but, this isn't really an off road rig so the 1356 would probably be good enough. The rear output I can modify to have a fixed yoke.
After quite a bit of research I'm running mobil 1 synthetic something in my ZF5. It was recommended somewhere to keep gear rollover quiet, turns out that didn't work, but it shifts well and unlike gear oil is thin enough to shift well. I had swapped to Redline MTL in my old VW jetta and that shifted awesome, I hadn't really thought of putting it in my ZF5, though its a good idea, just a bit pricey for the amount needed.
BTW, there are fixed yoke BW1356 units, I want to say Bronco's had them? I would also prefer the fixed yoke, but have very little trouble with the 1356 in my truck. There was a small issue with the linkage inside popping out of place, but the only effect was it wouldn't shift out of 2wd, and was easy to spot and fix when I popped the case open.
51Super
12-09-2007 01:19 PM
cgrandahl64
01-02-2007 09:14 PM
Craig5_12
07-26-2005 08:49 PM
