2007 Explorer has 8 DTCs
Hello,
My name is Michael West. I recently had a check engine light come on in my Explorer and the codes are
P0102-MAF
P0135-O2 SENSOR
P0141-O2 SENSOR
P0155-O2 SENSOR
P0161-O2 SENSOR
P0403-EGR
P0443-EVAP CONT. VALVE
P0613-TCM
All the codes came on at once and when I am cruising at a steady speed it runs fine the only problem is at idle it sputters out and dies. Black smoke comes out the exhaust pipe and also what I think is liquid gas coming out the exhaust pipe is leaves a nasty black splatter/spray right behind the Explorer under the exhaust tip. Everything started when my wife filled up with gas at a Get-Go gas station its a grocery store chain here in MD, she called me and said she got the gas and before she could take the kid to school it was shaking real bad at stop lights and I'm not sure where to start with all these codes I am a Wheeled Vehicle Mechanic in the Army so I know my way around a wrench just use to working on diesels and a lot bigger trucks any advice would be great.
Thank you
P0102-MAF
P0135-O2 SENSOR
P0141-O2 SENSOR
P0155-O2 SENSOR
P0161-O2 SENSOR
P0403-EGR
P0613-TCM
Thank you
I wonder if the gas had something in it ? diesel ? ethanol content ? water ? .......... if it happened right when she filled up, I think I would drain it back out... You could suck most out thru the filler cap ........... If the gas you normally use is gasoline, you might try 5 gal of 10% ethanol gas to see if it was water contamination.
--- might talk to the gas station and see if they have had others complain ?
Weaselpolooza
1983 - 2012 Ranger & B-Series
01-13-2007 05:31 PM
